After checking the magnetos earlier today, I noticed some very slight seeping of brake fluid at the AN822-4D fitting that screws into the brake cylinder. I installed those fitting years ago and I thought perhaps I did not screw the fitting tight enough or did not use the proper Permetex on the threads? I disassembled the cylinder from the wheels which you have to do to remove the fitting. I cleaned up all the brake fluid that seemed to be everywhere and cinched down those fitting real good after applying Permetex to the threads. Tomorrow I will install some prefabricated brake lines I had purchased at Pegasus Racing some time ago in anticipation that someday I would use them and tomorrow is that day. Pegasus carries these prefabricated hoses for only 19.99 each. Part number is 4-36-S-S. These hoses use crimped hose ends which cannot be removed. All hoses are proof tested to 3,000 psi before shipment.
